Trailer Jetter Finished
  • Trailer Jetter Finished
    Well I'm almost done putting it together. It's up and running, just a couple of trim pieces left. Used it Friday on a grease line. I don't no how I worked all these years without one.
Size:  488.0 KBName:  6cdee314e8c8a4275c672181d261e63b.jpg
Size:  489.2 KBName:  a1eb24513976cb36a41e1ca9f9febcd4.jpg
Size:  503.5 KBName:  f2c51bd73b3dd56cc9add0f292aee742.jpg
Size:  495.9 KBName:  2b03e9c8316579bee4994ba5ffb464c1.jpg
    Re: Trailer Jetter Finished
    Looks really really nice! I used to be set up just like that in an enclosed trailer, only thing I notice is I had to place sheet rubber between the pressure washer skid and the trailer floor because of vibration tearing up the floor in my new trailer.
    Seattle Drain Service
      Looks custom !
        Looks really nice.
        I know nothing about these systems beyond what their purpose is...
        I'm sure that the unit w/ the flue and thermostat on it is an inline heater w/ a heat exchanger or something? It's capable of keeping up w/ the GPM that your pump is capable of I'm sure... Any more info for those of us who haven't used this equipment before?
          What kind of metal pipe & fittings do you use on the pressure side?
          Thanks.
            There are vibration dampers between the 1/2" mounting plate and the frame. This thing runs wide open with no vibration felt on the floor.
              Originally posted by dlarrivee View Post
              Looks really nice.
              That's right its a hot water high pressure, oil fired heater, 3000 psi, 4gpm @ 200*F. The unit itself is a Kohler 38hp, the pump puts out 11gpm @3600psi, 325 gallon holding tank.
                Wow.
                So you could empty that tank as quickly as half and hour if the water didn't need to be 200*F...
                The heat is for grease/scum, I imagine?
                  Do you feel you come out with less cost (materials and labor) than a pre-made setup? Or did it cost the same and this was just more fun?
                    That is a really really nice set up. I like the multiple choices of reels and the fact everything is enclosed in a trailer, giving you a large area on the exterier to advertise with.
                    Great job!!!
                    Plumber Raleigh,Plumber Cary,Plumber Apex ,Plumber Apex, Plumber Morrisville,Plumber Durham, ,Plumber Holly Springs,Plumber Chapel Hill,Sump Pump Raleigh
                      Great job!!!
                      Thanks, also being that I have to heat it in the winter. The trailer itself is 7'x14' that I insulated before doing anything. The walls and ceiling are insulated R-15 and the floor R-24. I have to insulate the doors before the cold arrives.
                        Very nice set-up!
                          Thanks.
                          Where did this answer go? It was there earlier. I might need the info later.
                            Lots of thought here,You're a great fabricator.
                              very nice design and thinking. is the hot for thawing frozen lines or cutting grease?
                              i hope you have electric or surge brakes. and don't tow full of water any real distance.
                              lets see some video of it up and running.
                              once again a real nice design and execution.
