New Nozzles from Mustang Nozzles Australia
  • New Nozzles from Mustang Nozzles Australia
    Side Cutting Nozzles
    Side Cutter Predator 3R1F with Screwdriver Blade
Name:	Predator Screwdriver Sidecutter sm 4.jpg
ID:	634992 Click image for larger version
Name:	Bandit Sidecutter sm.jpg
ID:	634991 Click image for larger version
Name:	Bandit Sidecutter sm 3.jpg
    Here are our 2 new 1/4" hardened stainless nozzles.
    We used a 4D CNC to make them.
    The first nozzle is a Side Cutter Predator 3R1F Screwdriver. It will bury into anything!
    The second nozzle is a Side Cutter Bandit 6R Thruster nozzle.
    The unique cutting action on the side of the nozzle assists in mechanically opening a blockage when the operator twists the hose. The channel rings around the nozzle are cut on a sharp angle to give the nozzle more surface cutting area.
    Regards, Bill
    The definition of Insanity: "Doing the same thing over and over expecting a different result."
    Albert Einstein
    Re: New Nozzles from Mustang Nozzles Australia
    bill, any video of them in action?
    what happened, your machinist forgot to remove the step drill from the lathe and made a nozzle out of it
      I bought the bandit sidecutter yesterday and already had much success with it........ Thanks again Bill for making our lives easier to clear blockages ....
        http://youtu.be/RATLdAFAXR4
        Regards, Bill
        Albert Einstein
