If you were in the market for a new cart/trolley jetter what features would you want?
  • If you were in the market for a new cart/trolley jetter what features would you want?
    Working Pressure?
    Flow Rate?
    Weight?
    Frame Material?
    Nozzles?
    Size?
    Built in Water Tank size?
    Fuel tank size?
    Hose Length?
    Hose Diameter?
    Regards, Bill
    The definition of Insanity: "Doing the same thing over and over expecting a different result."
    Albert Einstein
    Re: If you were in the market for a new cart/trolley jetter what features would you w
    It has to fit in a american van and cut roots all day long in 4" and 6" pipe up to 200'.
      Originally posted by bill2601 View Post
      Working Pressure? 3000+
      Flow Rate? 5gpm+
      Weight? Don't care
      Frame Material? Don't care
      Nozzles? Root ranger and warthog for big pipe and 6 nozzle ball nozzles along with spring style drop nozzles.
      Size? Footprint size is more important then height imo
      Built in Water Tank size? Whatever works but will have a garden hose to supplement water
      Fuel tank size? Run for 6 hrs straight+
      Hose Length? 150'
      Hose Diameter? 3/8-1/8
      [ATTACH=CONFIG]15692[/ATTACH]
      Can't see your attachment. Would also want intergeral lifting attatchment. Be able to handle up to 6" pipe. Send me your prototype jetter and I'll give you and the forums some real world reviews of your products.
        Working Pressure?
        Flow Rate? 6 gpm
        Weight? under 225#
        Frame Material? high strength aluminum or stainless.
        Nozzles? rootranger higher flow with a good forward jet when needed.
        Size? not to exceeded 24'' in with and 36'' in length. not too top heavy. 4 good rolling wheel with a built in brake system.
        Built in Water Tank size? 10 gallon max.
        Fuel tank size? 5 gallons
        Hose Length? 200' of 3/8''
        Hose Diameter? 3/8'' or 5/16'' dual reel 1/4'' and 3/16'' for smaller lines. 1/8'' is too much pressure drop.
        working on new toys bill
        as ben mentioned a good center point lifting eye.
        any chance of having a pump that could handle 150 degree water?
        also mine home made remote 4 channel valve is the best . this way you can work without a foot pedal or shut off if need be. great for large jetters. might not be too critical for 6 gpm as a foot pedal will still work fine.
        you got my number
          We are building a totally new trolley with all the goodies for under 10k. Thanks for all the input, I'll let you know what we come up with!
          Regards, Bill
          Albert Einstein
