Jetter Set Up
  • Jetter Set Up
    I'M thinking of going into the jetting business...was looking for some recommendations on a STARTER Set up
    1.Type of jetter(will be doing mostly residential some light commercial)
    2.Hose Size
    3.Knozzles I should Have
    All Help will be appreciated
    Re: Jetter Set Up
    Before the real jetting experts step in, I will ask for them: What size and type of pipe (cast iron, clay or PVC......4" or 6") and how long are the runs.
    For example I happen to be planning for a similar endeavor next year and I will need to do 6" Clay X 200' max.
    I have been considering the KJ-3100, the General J-3080 and after reading from the jetting pros on here, possibly building my own cart jetter with the ability to get over 4K psi @ 7-8 GPM
      Re: Jetter Set Up
      If you are only going 4" on down the GX390 Honda powered jetter at sewer jetter pressure washer plumber's special is a cheap way to get started.
      If you need to go bigger than 4" you better find something bigger like 5-6 gpm with 3/8" hose.
      Pressure cuts, flow flushes, but if you are going to try to run off of a garden hose with no reserve tank I personally wouldn't go much over 5 or 6 gpm or the water supply could be a little short on some homes with poor water pressure.
      Rick, JRSaltz, Cuda, and others can give you all the advice you want and more, or do a search and you will find endless threads on the topic.
        Re: Jetter Set Up
        Listen carefully you are definitly going to want a jetter reel, hose spining machine. Without it you wont be able to jet anything less than 2 inch without alot of frustration in getting the hose thru the 90's
