Re: 1/4" vs 3/8" jetter hose
so thats why bill like to run 5000 psi.............i get it Thanks
We would struggle using 3/16" hose with 3000psi. Rick is right, I like the higher pressure so I can use smaller hose to get around our tight traps and junctions. I can get 3/16" around a toilet bowl with screw on nozzles, not quick connects!
stolen, actually just the opposite.
i would use the 1/4'' hose on the 2'' and smaller lines. the 3/8'' hose on 3'' and larger.
the pressure drop on 1/4'' at 5.6 gpm would be beyond my chart. but at 4 gpm, it's approx 4.75# per foot. so at 200' that's 950# loss. plus it will cycle your unloader as 1/4'' is undersized for 5.6 gpm.
the 3/8'' hose will only lose 1.25# per foot at 5.6 gpm. so 200' would be a 250# drop.
whenever possible use the 3/8'' hose.
bill in australia jacks up the pressure to overcome the pressure loss. therefore he still ends up with decent cutting pressure.
I don't know anything about jetters, but I would assume the pros would be more flexible for smaller lines, but that is probably it. You would lose volume for sure, but pressure would be the same.
I think..
Check out My harbor frieght, 5000 psi, 3/8" quick disconnect, in line guage $19.99 Great quality . Know pressure at the end!
my jetter specs are 18 hp 5.6 gpm @ 3600psi i use 200' of 3/8" hose with the nozzle end being crimped with a 1/4" mip
As i see in bills videos looks like 1/4" or 5/16" hose. Should i be using 1/4" hose how much would i gain or lose by goin down to 1/4" hose?
I know i would be able to make more corners and bends with 1/4" hose but what are the pros and cons of smaller hose?
What are you guys using?
