new tool for k60
  • new tool for k60
    i just spent several days pulling heat tape into 3" cast roof drains 100' runs 8-90s this is a tool i came up with in a pinch.Click image for larger version
    Re: new tool for k60
    looks good. but i can't use it for heat tape
    although i've seen many cable tv wires run down the downspouts
    is that a swivel so you can motor the cable back if needed?
      So you're pulling heat tape inside of roof drains?
        Don't know about his install, but in a lot of cases in our area, the roof drains get insulated, "condensation maybe?" and it makes a lot of sense to run it In the roof drains, as long as they are protected with screens or strainers to prevent debris.
          this is a poorly designed project thrown up for the olympics . roof drains (should) run through heated space these are in chases on the exterior . they froze ,broke ,and flooded several condos . we used a hot jetter to thaw solid lines and replace broken sections in -21 temps so the heat tape to avoid that he!! again. i would like a more robust swivel.(it is to keep the wire from spinning if I have to motor out) the blue wire lube helped as well. and we could all join blue man group when done. well i would need a hair cut. the electrician and i are licensed .
