Getting fed up with this snake
  • Getting fed up with this snake
    Second time it's happened now. I have one of the Ridgid drill snakes with the auto feed, can't remember the model number but it's the Grey or black colored drill not the new red one.
    The motor just wants to quit as if the windings are messed up or something. Sort of stops then goes then stops. Sent it back to Ridgid last time and they said they rebuilt it. It's worked fine for a few months and now it happened again. No way do I abuse it, don't even use it that much really.
    It sure seems that this drill snake is just underpowered and a real piece of garbage.
    Question is did they improve the new red one I hope? And if so what was wrong with the old one. I'm sending it back again and this time asking for a replacement, this is crazy.
    Re: Getting fed up with this snake
    I own 3 K-39's and they all run great. Sounds like you got a lemon
    The K-45 is a better built unit but the K-39 does the job just fine.
      I love my k45 it rocks
        That's what I'm thinking too and that's what I'm going to tell them when I call on Monday, and send it back, again.
          I have had a generak supervee for 9-10 years now, same one, just has electrical tape on the cord, havent changed anything but the cable and the screws that hold the drum toghether. Best top snake ever.
          Plumber Raleigh,Plumber Cary,Plumber Apex ,Plumber Apex, Plumber Morrisville,Plumber Durham, ,Plumber Holly Springs,Plumber Chapel Hill,Sump Pump Raleigh
            Love My RUGED SUPER Vee
              i own more k-38 and k-39's than i can count. use to carry 3 in the big truck. but since i switched to the sprinter almost 3 years ago, all i carry is the 1 k-39. according to my invoicing, it's been billed out 1008 times i would say it's paid for itself
                K-39 AF is an underpowered turd... Thus the reason Ridgid developed the K-40. The problems I had with the K-39 centered around the digital proportional controller built into the trigger. I ended up taking the drum and AF off and putting it on an older K-38 and have been happy ever since. Ridgid really needs to slow down on its product obsolescence plans (I'm cooking up a post about this)...
                  Thank you, I thought I had heard that before. Thanks for confirming it. So real people ARE having trouble with it and it's not just me. I want them to send me the newer more powerful tool this time if the old one was not sufficient to do the job and they knew this. If not then I'll go to a different brand. Stand behind your tools Ridgid or else we won't use them. It's really just that simple. Also I shouldn't have to have a truck load of the same tool, what is the point of that? Why would you even do that?
                    They pay for themselves with one service call in most cases and when they're sitting in the shop because they don't work I'm losing money. I like this snake, when it works.
                      Been using the k50 more with the 5/8 cable. I don't mind the extra weight.
                        How much power do you need in a pistol rodder ? All of mine have enough power to snap or pretzel a 5/16" cable at will and then some.
                        K-40....???
                          K-40....???
                          More then what the K-39 has I really think the problems with the K-39 centers around the digital proportional controller built into the trigger not letting the current get to the motor. The motor spins the drum ok but it does not hold a candle to the RPM's / cleaning action of my K-38 frankenstein I do not own a K-45 but would be willing to bet it can spin faster then the K-39AF.
                            More then what the K-39 has I really think the problems with the K-39 centers around the digital proportional controller built into the trigger not letting the current get to the motor. The motor spins the drum ok but it does not hold a candle to the RPM's / cleaning action of my K-38 frankenstein I do not own a K-40 but would be willing to bet it can spin faster then the K-39AF.
                            Yes I do remember now that when I returned it the first time they said it was a problem in the trigger mechanism area and they replaced something. It's boxed up and on it's way to Ohio in the morning for the second time.
                              Its * k45 Not 40
