K-39 or other top gun in toilet ?
  • K-39 or other top gun in toilet ?
    Ever do it ? If so, any home made guides to protect toilet ? Was thinking liquid tight
    elec flex conduit would work.
    Re: K-39 or other top gun in toilet ?
    I kept a section of 1-1/4" pvc with an electrical sweep for this.
      Why not use a toilet auger ?
        Or carry ?* extra wax ring
          Have done it with a k 50 5/8 cable 35 feet baby wipes.
          Rick.
            Of course I have a toilet auger,But a longer reach May be needed at times
              Kevin,
              You are the King of fabrication and you have all the right tools.
              Get to it MISTER!!!
                Tried it for 2 seconds with a k39. Difficult to hold onto the guide and gun at the same time. Came to my senses and pulled the toilet. I can see Rick's way working with 5/8 cable but never 5/16 or 3/8. That was one of my uh-oh moments.
                  Thanks Gear. Got one tomorrow,I'll hit the stack.
ID:	626465 Here you go this one is by General.
                      Originally posted by SewerRatz View Post
                      [ATTACH=CONFIG]15873[/ATTACH] Here you go this one is by General.
                      Tanks boss. will be fabed before 9 am .You DA MAN
                        Why do you want to run such a small cable through a toilet ? Where do you suspect the blockage is ?
                          1" PVC "Cross" With the end heat formed after hitting with roofer's flame thrower
                          Your buddy Josh made one out of 3/4" for his little camera
                            This is My best customer. Over the years I've done around $600,000 worth of improvements. Well I fab up the dinky Lil toilet attachment Rats posted,Tanks Rats. Nice to use the super vee , Nada. Pull toilet, K-375 3/8" cable. decided to play catch the pretzels old Man,if You can, O'Fk that smarts. Sorry Dr. Go down to clean out in dirt crawler. Pop cap,eat 3 storys of brown corn.
                            Bring the Mr. Maxi rooter in, It also wants to suck Me in. Was playing nice then ROOTS FROM HELL! Wow , I now only have 2 fingers left! No problem Doc,all the drain Guys have stumps! Yippy 8 billable Hrs.My incompetence pays handsomely!
                              Doc said 2 weeks earlier, He had a slow Tub. Had a Guy snake that also. Can't make any connection. Do You?
