No Corrode Sewer Pipe and Jetters
  • No Corrode Sewer Pipe and Jetters
    I am buying the KJ-3100 and am wondering if anyone has experience with cleaning 4 inch no-corrode sewer line with a jetter. Do you ever have to turn down the PSI in order to not cut through this stuff???
    I know that when this pipe pinches and you try to clean it with a 4 inch or 3 inch cutter, you can put a hole through it.
    Any advice would be helpful.
    Re: No Corrode Sewer Pipe and Jetters
    Never heard the term "no corrode" pipe. Can you explain. Congrats on the jetter.
      most likely he's talking about orangeburg pipe. Sewer History: Articles
      a jetter will defiantly soften the pipe is left in the same spot.
      the pipe is nothing more than wood cellous and tar, pitch.
      a snake will also damage the line if the pipe is not round.
      not much you can do. if it's broken, replace it. a jetter will be safer on oval pipe, but you have o keep it moving.
        About half of my City is built with this stuff. The Municipality calls it "No Corrode" Pipe. Rick is right ^^^
        Here, the sewers are 6-10 feet underground. I have made a small fortune off of replcacing these when they collapse or pinch so badly that it cannot be cleaned(usually $2400)
        I have to clean these pipes EVERY DAY, but I've only done it with cables and cutters.
        Thanks Rick!
        I will also ask around to some of my friends who are oddly also my competitors.
