K60 not getting much use these days.
  • K60 not getting much use these days.
    Started using my 1065 again because of a job i needed it on. Filled it up with 11/16 cable to get thru whole house traps and noticed a huge difference in weight. I like sitting on a bucket and letting the machine do all of the work. I was using my K60 so much i forgot what it was like to cable with a drum machine. Each have there use but i think for now i am keeping the 1065 on the truck and its going to get used more often. Sorry sectional guys.
    Re: K60 not getting much use these days.
    Idon't use mine much also but I'm glad I have it. I have alot ski lodges where getting into the places are a pain in the butt. Go into the building up a flight of stairs across an upper kitchen/ living room area then down a flight of stairs into a small hallway with bedrooms on each side and a very small bathroom where 99% of the time I have to pull the toilet.
    Rod
    http://unclognh.com
      Rick will be most dissapointed.....
      Derek
          "IN" before the gloves come off in this thread.
            my 1065 has sat at the shop since i got it. used it a few times and retired it.
            the k-60 does 90% of my cable cleaning jobs. the 1.25'' sectional and timberwolf does the rest.
            and my jetter does everything i take it on. like the 2 jobs today. nothing like being able to clear a root stoppage from a 4'' buried comby in the opposite direction with a 3/8'' warthog nozzle at 4000# and 11 gpm. can't do that with a cable machine. although i can do it with a 7/8'' sectional k-60 and reverse auger.
              Sold my K-7500.Did not use it once.
              If I'm going to haul heavy weight it is going to be my cart jetter.
                Yep or my 1500
                  Rick, I have rodded the opposite direction in a 4" combo many of times with my 1065 and its 3/4" cable. Now doing that with the k60 or k1500 will never happen.
                    i've done it multiple times with my k-60 and reverse auger without a problem. running in reverse actually threads it into the line and the reverse auger does a good job on roots with its open wind and 45 offset.
                    i can't picture any kind of cutter on a 3/4 drum can make it. and we all know a sectional open wind cable will clean a line and grab roots much more efficient than a tight wind drum cable.
                    how deep are you able to get a 3/4'' drum cable into a 4'' comby riser and make the reverse direction?
                      The deepest 4" wye combo I have rodded the opposite direction was 7' with a 3" pair cutter.
                      We have a subdivision where they installed an outside clean out just in front pf the homes, its a 4" wye combo. Nine times out pf ten its plugged under the house with a finished basement. So i put on the 3" cutter do my loose knot with a string and make the rod go the opposite direction of the wye.
                        How do you pull it back out?
                          It comes rifht on pit with ease.
                            I've rodded the opposite direction in a combo with both the 7/8" and 1.25" cable.
                              You speak the truth.
                              Drums do more work, but it's usually more work to get them to the cleanout than a sectional.
                              A sectional will go on roofs, down into small crawl spaces etc. And since you carry it, it can't leave track marks like dirty wheels from a drum machine (got a lady's stairs really dirty with the K-7500)
                              I've used both and will never go back to a drum machine.
