Gravel in Sewer Drain Pipe
    Re: Gravel in Sewer Drain Pipe
    Hi Cuda (and others),
    Have got a permaliner contractor who apparently has a "pull in place system" who will be looking at my pipe tomorrow. Says that the tip of his "snake" [my term] can move stones forward or backward and didn't mention that he had any problems with the cleanout. (Did mention that he invested $350,000 in the system, so I am assuming that he has the "pull in place.") Are there any particular things I should be aware of before I agree to use this system and contractor?
    Thanks again to everyone,
    JD
      only thing as the client I can think of are.
      1. After all lining or patching that is done that no other connections have been blocked off by the lining process.
      2. Lining is done to local codes, some places have no codes others may want a DVD of the completed job. To make sure it does not protrude into the city sewer.
      Seattle Drain Service
        jetting is a good idea. You may try forcing a 2 inch vacuum truck hose down your 4 inch cleanout and sucking the gravel out. easier to do when someone is fixing the hole
          Signed a contract for $3850 for 20 feet of permaliner and cleaning out the gravel. Will let forum members know how it goes.
          JD
            The permaliner contractor came today and things did not go well. They didn't bring their 4,000 psi jetter (truck broke down yesterday) and instead tried to use a 2,000 psi jetter. The actual people doing the work seemed to be working hard, but I wonder whether they had the tools for the job. In any event, after about 4-5 hours of trying to jet and suck the gravel out of the pipe, they gave up and said that the suction was just bringing in new gravel and that the only solution was to dig 15 feet deep and put in 30 feet of pipe. [my house is on top of a decent sized knoll. The pipe from my basement foundation could be 15 feet deep, but it is something I would like to be sure about.] One complication is that the hole in the pipe (as seen by video) is about 1 foot from the basement foundation and is under a concrete porch.
            Now the permaliner contractor is saying that I need a substantial dig to put 25-30 feet of pvc pipe in. The cost of the proposed fix is about $9,800 and doesn't include "concrete repair." I would like to better understand why the hole near my foundation can't be fixed and why the gravel (it typically is about the size of a quarter -- it is much bigger than pea gravel) can't be jetted out after the hole near the foundation is patched either temporarily or premanently. Also, general suggestions as to what to do in this situation. Would add that I paid half of $3,850 upfront [they want an additional $7,700] and that I now have a hole to the basement pipe already dug out, which should aid a new contractor if one is needed. Thanks for any help that can be given.
            JD
