How To Post Images
See more
See less
i have bought a new small jetter good choice ?
  • #61
    Re: i have bought a new small jetter good choice ?
    Wow!
    J
    • #62
      I think that was my problem, I couldn't get past the roots. It finally did the job but took a long time. I need a foreward cutter like Plungerman has and a push rod I guess. Any help on a long push rod ?
      • #63
        Look up duct rodder or similar. I like Jameson but there are many others.
        AllurePlumbing.com
        • leak detection
        • drain cleaning
        • utility locating
        • conductor fault locating
        • and other specialties.
        • #64
          How is this fiberglass rod attached to the jetter line?
          • #65
            I am sorry If I ask to much.
            And it is not true that I have bought so many jetters, I buy one and if it is not good I sell it again. At the moment I have got 3.
            On the market are so many jetters and companies so it is dificult to make the correct choice. I only look to have the best for the money I can spend.
            Both of the 2 jetters cost about 3500 euros = 4683 Us Dollars.
            The one with the kohler motor is cheaper because it is an not knowen company and the hoses and accesories are not so good. What I have told they sale it only with rubbered hose like the normal pressure jetting hose.
            The other one is an known company with good hoses and also triggergun and small sinkhose.
            • #66
              Sturdy tape of your choice. I used duct tape. Good luck.
              • #67
                What size fiberglass rod will push through 3" and 4" 90's?
                • #68
                  I use 1/4". I believe Gear uses 5/16" and evidently goes through sanitary tees.
                  AllurePlumbing.com
                  • leak detection
                  • drain cleaning
                  • utility locating
                  • #69
                    I bought 1/4 after a hands on bending of it. havent used it yet but am confident about getting through 3 & 4 and stiff enough for sure.
                    • #70
                      Hello again,
                      I have just been to an company which close their business.
                      they have 2 jetters and i will choice one of tham:
                      22 Ps Honda 3000 Psi 8 Gpm
                      25 Kohler 2460 Psi at 11 gpm
                      I know guys you like the higher pressure. But in this case the secons option will be better or not, theie is not so much pressure differenz but more gallons.
                      What you can advie. it will be used for 4" drains pipes and also for street main one 6-8"
                      • #71
                        Sorry but i will do also 10" drains and small sink drains.
                        • #72
                          @Rick,
                          I am trying to send you an PM, but no way. I would like to ask you some questions, and also about this two machines in the post over here.
                          Thabk you.
                          Thomas
