Stubborn drain
  • Stubborn drain
    This last week I worked at a building that is worse than cursed. (I won't bore you with details) The place should be completely replumbed as far as I'm concerned.
    This one apartment had a plugged kitchen sink (which they didn't mention) a plugged tub, a plugged toilet, and a plugged wall hung lav. (Yep, every plumbing fixture in that unit.) It turns out it wasn't a main line that was plugged, but rather, each fixture was plugged separately with hair.
    I used a 3/8" drop head in the lavatory. On the 1st pass I sent it out about 30 feet, and a good gob of hair came back. On the 2nd pass I put a nice hitch just behind the drop head and sent it out 30' again. The line is 1-1/2" galvanized with a reducing brass trap adapter 1-1/4". On the retrieval I got the snake back within five feet of the drain opening and the snake became stuck. It wouldn't come back any further. It would go out a little, but not back. So naturally I tried back and forth till the snake was simply stuck, and the cable decided to twist on me between the wall and drum. Three fingers on my left hand were stuck in the cable for what seemed like several agonizing minutes, although it was probably less than a minute. (After a screwdriver and pliers with my right hand failed, I finally just pulled as hard, and painfully as I could to get my fingers loose and succeeded. Thankfully I had a glove on!!! (ALWAYS)
    Anyway, no broken or crushed bones and just small blood blisters under my finger nails.
    Here's a pic of what stopped the snake cable. After I cut the pipe it wouldn't fall loose because the hair ball / plug was simply too tight. The hair ball was about 12" long and wouldn't get through the 45 ells upstream.
    Oh, and I left out the best part! The smell was so strong in this bathroom that a plumber who was using a shop vac to clean the crap from the toilet and tub lost his lunch! (Which was too bad since we had enjoyed a very nice Sausage and mushroom pizza with extra cheese at lunch)
    Re: Stubborn drain
    That photo is disgusting with all the oozzzzz on it their should be an R rating on it
    Tony
      Re: Stubborn drain
      Thats a hair ball
        Re: Stubborn drain
        I love a good plumbing horror story
          Re: Stubborn drain
          Tony
          Tony, That "oooozzz" is below the apartment but in the ceiling space above a Mexican restaurant. Now you know where that "special" spicey flavor comes from.
            Re: Stubborn drain
            O no I`ve lost my appetite you are so cruel
            Tony
              Re: Stubborn drain
              Did You get Hazardous duty pay ????
                Re: Stubborn drain
                I think I saw that in a movie once...called the Thing......
                Derek
                  Re: Stubborn drain
                  I haven't billed him yet. One thing you can count on... I'm going to give him a haircut.
                  (just kidding)
