Crawling drain robots
  • Crawling drain robots
    Is there ANY robotic tool out there that:
    A) Can, under its own power crawl down into a 1/2"-1" drain system?
    B) Can pull a small wire cable through with it
    C) Can negotiate ells, Tees, and Y's
    D) and then crawl out at a different drainhole, so the wire can be PULLED out afterwards, to clean any existing debris?
    Thanks, Frank
    Re: Crawling drain robots
    frank, either you're dreaming
    or you just invented an amazing tool
    let me know when it's available and i'll buy one.
    but for now, my seesnake micro or the nano cam is the best we have
      the robot for the 1/2" drain would have to be the size of an ant.
        Well my cell phone used to be the size of a brick today it's so small.
        But today is not that day yet for mini mini drain robots
        Seattle Drain Service
          A 1/2" drain is smaller than I'm used to. Maybe a condensate drain on a tankless water heater..................................
          David
            I been trying to train a cricket to pull a string
              Thanks, Frank
              Its funny as I was just reading your post and I have just what you are looking for on the upper shelve in my gargage and does all of what you require just send me you credit card number name and expirary date and I will forward it directly to you cross my heart and hope to die
              Tony
