pull efect of root ranger nozzle ?
  • pull efect of root ranger nozzle ?
    Hello,
    How good is the pull efect of the root ranger.
    Did I need to help pushing to go thrugh an 4" pipe ?
    Jetter: 4 Gallons 3500 PSi.
    Hope somebody wil answer, or are you all on holidyas ?
    Re: pull efect of root ranger nozzle ?
    the rr will pull very well up to about 150' or so then it will start to struggle
      a slick hose is important. not a rubbery hose, the rr polls great due to the 1 rear rotary jet.
      the only negative of the rr is you need to rotate the hose to get the jet blast to clean the top of the pipe. otherwise it does a great job on the bottom and sides.
      your jetter specs are right in line for the 1/4'' rr jetting.
        Rick,
        Will you recommend a good company to buy "slick" hose from?
        Thank you.
