Electric Pressure Washer (not for drain cleaning)
  • Electric Pressure Washer (not for drain cleaning)
    Looking for a electric powered pressure washer in the 3000- 4000 PSI range.
    This will not be used for drain cleaning but will be used for cleaning of concrete
    to remove old coatings and general built-up grime and dirt in preparation for
    concrete repairs and/or re-coating.
    Voltage is not a concern, I have 120, 240, or 480V available. Want something
    portable on a cart so we can move it around the building easily.
    Any recommendations on units to avoid or those that you have used and like.
    Something like this:
    http://www.daimer.com/pressure-washe...ax-12300af.htm
    Re: Electric Pressure Washer (not for drain cleaning)
    see what cam spray has or can build. probably something in the 7.5-10 hp range will be about right depending on gpm.
    www.camspray.com
    Cam Spray Base Mount Series Electric Pressure Washer Cam Spray
      see what cam spray has...
      Put me down as another vote for Cam Spray. Expensive, but good stuff.
        Rick, you say 7-10hp, are you talking a gas powered unit?
        I need something that is purely electric driven as it will be used indoors.
        I will check them out though.
        Nevermind, i see in your link it is electric.
        Thanks everyone for your suggestions.
