Jetter hose
  • Jetter hose
    Im in the market for new jetter hose 3/8" x 200'
    What are u guys using and likeing ?
    and where to buy ?
    Re: Jetter hose
    Are you looking for flexible hose or stiff hose.
    Do you need to pull a lot of hose to the clean out?
    Are you right over the top of it ?
    What type of pipe ?
    All these question will dictate what you buy.
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
      Re: Jetter hose
      the hose real sits right next to the 4" castiron cleanout that service a 6" clay sewer line
      I run a jumper hose from the machine to the real in the basement
        Re: Jetter hose
        I tend to run the cobra brand for this type of use because its inexpensive and a tuff hose. I do like the piranha hose but I feel it is to flexible when it is not under a load, so it kinks easy with no pressure.
        There are many different hose makers and everyone uses something different. If all your jobs are this and straight runs I think the cobra brand is ok. It is much stiffer than others
        On my Spartan 758 I have 350’ of the 3/8 piranha and 100 + of the cobra brand.
        the cobra is more user frendly
        Appleton WI, 54915
        1-920-284-7471
