drop header
  • drop header
    Is there a shorter drop header then the t-217? I had a tight situation today that the t-217 couldn't negotiate. I was able to hand feed a 1/4" cable but I would has liked to use bigger auger( 1.5" galvanized line that probably still has lot of rust/minerals in it). Thanks
    Re: drop header
    Cut some off the end ???
      Re: drop header
      the 217 fits both the 5/8'' sectional and the c-6 3/8'' cable with 5/8'' connector.
      have you looked into the c-2 cable with built in drop head? not sure of the exact spec other than a 25' cable with drop head.
        Re: drop header
        Forget them. Have snapped a few off .Now go make yourself a reverse auger
          Re: drop header
          I looked into the c-2 cable but haven't found any specs. The reverse cables are great but wont work in all situations. Does anyone have the c-2 cable or know the specs? Thanks
