Adjustable Cutters
  • Adjustable Cutters
    Is it me or are they made to fail. Anybody use one? Spartan wants $98 for their 4"-6". Am I just better off with the offset blades?
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
    Re: Adjustable Cutters
    i have a few 4 x 6'' ridgid and even their monster 6 x 8'' . they are really designed as a finishing cutter. very heavy blades, but no teeth. you really need the 1.25'' k-1500 to spin them. i use it on my 1.25'' with my timberwolf. i also use them when i was running my 7500 drum and i modified the holder to fit the 7500 cable.
      I have a 1065 with their magnum cable. I think the machine can handle it...more concerned with them holding up....errr was, if you use them, I will consider them.
      AllurePlumbing.com
      • leak detection
      • drain cleaning
      • utility locating
        I have the eel 4 x 6 expander blade, it's very nice but I haven't used it in two years. Jetting is so much easier plus it gets better results.
          Its only a matter of time for me and a jetter.
          AllurePlumbing.com
          • leak detection
          • drain cleaning
          • utility locating
            I use the Electric Eel expanding cutters. They are very well built and work very well. They are also very expensive. They are finish cutters.
            Will Rogers Plumbing
            Moore, Oklahoma
            405) 323-2852
            www.willrogersplumbing.com
              We use the general 4x6 and they cut like a devil when new but wear down pretty fast in cast. Definitely a finish blade like the others have said but they do the job.
                The city I moved into 21 years ago, requires you to call them so they can witness the power rodding of the main. Also they require you to use a 4 x 6 expanding cutter. So back then I had Marvin at Allan J Coleman make me up a Ridgid expanding cutter, with a Spartan style pin lock end. Over time this evolved to the Ridgid expanding cutter to be welded on to the end of a leader for magnum cable or 3/4" cable depending what cable I was using with my 1065. Never had any issues using them on the 1065, the sewer inspector for this city was impressed as well.
                  thats redicilous so when someones mainline is backed up and there house literally has **** coming up.... you have to call a inspector out to have him watch you clear the line?
                    Ratster, talk about beaurocracy run amok!! Will the city guy help you pull the machine back out of the basement when you're done?
                    I use an electric eel 4x6 expanding cutter on a 1.25" leader which is welded to a 3/4 spartan connector, and that's reduced to .66. which I use on my Spartan 2001. AJ Coleman came up with that baby and even did the welding. If memory serves it cost about $500 but is worth it imo.
                      I USED to have a Ridgid expanding cutter. That is until I lent it to a "good" mate. Somehow it never made it back to me and all of the excuses given. I am sure it was returned - not...!!!!
                      Nowadays however we generally only use jetters now. I know we all have preferences but cable is too harsh and severe on drains here. Mind you its not easy. Dare I say this too we have Billi-boy there with heaps of spares. cant wait till he opens up his jetter school. Might put my hand up for a gig on that one..............!!!!
                        can i be a substitute teacher too
                        forget bringing apples, bring me a shake
                        problem with the 4x6 ridgid cutter is just as easy as it springs open, it springs shut. i believe it's the centrifugal force that keeps it open and the more speed, the better chance it stays open.
                          They take responsibility from the sidewalk on to their main. So they want to witness the rodding to see when the line opens, and to determine if its in the ROW or not. Even if it is midnight, they want to be out there. We just call the local police non-emergency number, and tell them to contact the person on call at the sanitary department and have them meet us at the address. I make it a point to do this for all my after hour calls. They do bring their own camera and televise the line after the rodding is done.
                          The city will dig and repair the sewer if the problem happens on their ROW, three times within a year. The first time they log it, the second time they reimburse the home owner for the rodding and the third time they make the repair.
                            If nothing else it keeps a person honest to their work.....not so much their fees but you can't get it all. Around here the attitude is its anybody else's fault/problem. Nice to see someone step up for a change.
                            AllurePlumbing.com
                            • leak detection
                            • drain cleaning
                            • utility locating
                              Get the Eel expanding cutter and the Eel/Spartan adapter for your Spartan 1065. The Eel expander is the best one out there IMO.
                              I would not recommend spinning a 4X6 expander with your 7/8" cables/K60. Get some 5X3 offset blades instead. In my experience, the K-60 will not effectively spin the "finish" cutters in 6" pipe. I have tried 6" C-cutters in 6" pipe and it was a struggle once out more than 45'.
                              -Chris
