Size of toilet water spot after clearing blockage
  • Size of toilet water spot after clearing blockage
    What is it that changes the size during clearing and after ?
    Re: Size of toilet water spot after clearing blockage
    maybe i'm just too sober, but i do not understand what you are trying to say here
      i think i talk tool
      does the bowl refill height, water level change after clearing a stoppage?
      only if you broke the weir of the trap with your auger
      there is maximum level a bowl will fill too. basically the weir of the trap to the point of overflowing. an under filled bowl level is usually a ballcock adjustment of the refill hose. or the wrong ballcock or too fast a tank refill.
        Thanks Rick,I went back today and raised height to 1/8" below over flow tube top.
          i think i talk tool
          i was too sober to understand
