Favorite closet auger ???
  • Favorite closet auger ???
    General 1-76fl-dh drop head Best ? Do You buy XTRA heads?
    Re: Favorite closet auger ???
    I do 95% of my toilets with a General 3' drop head.
    I also carry a General 6' bulb head & the General DIY auger.
      Why not just carry a 6' one ? Is the torque stronger on the 3' one ?
        I have been using a Ridgid K-6 straight auger. Never had any issues with my Ridgid auger. The only thing I do to it is used a chisel to cut the first two winds off the front of the auger to make more of an open hook.
        I have seen to many guys blow out the tops of the traps with a drop head auger. The metal ring around the drop head knuckle has tendency to hit the top of a trap when they are working a blockage right at the top of the trap, and that ring with the torque they built up just blasts a hole through.
          Great advise ,I only have the 6' Ridgid. Will do the coil cut. Tanks Tool
            I use the 6' general . Also works great for shower drains.
              With out drop head ??
                No drop head . I used a auger with a drop head where I used to work and could not stand it.
                  The 6' is heavier and it also doesn't turn/spin as easily as the 3'.
                  The drop head hook is excellent at pulling out items that the bulb head will not grab unless you modify the end.
