drill and eel
    Re: drill and eel
    simon, the metric to american measurement should be 15' glad you guys downunder are using our american trick. just like the root ranger trick you've shared with us.
    have you seen my double barrel root ranger post? bills got a winner
    Sorry Rick you are correct, I did know it was 15' but forgot,
    Bill is on a winner with the Double barrel root ranger.
    Simon
      Re: drill and eel
      16+ years of running the drill and eel you can't go wrong it's a beast "I Know that guy in the video" Light, powerful and get in tight spaces it's a win win....
      Rod
      http://unclognh.com
        Re: drill and eel
        I really should remake the video to see it better now that we have WIFI finally and that I lost 50lbs lol......
        Rod
        http://unclognh.com
          Re: drill and eel
          hey Rod could you make another video but a little more involved.... and better quality lol
          like going through the whole job would be sweet im interested the time saving involved and cant wait to pick up a setup but im kinda bummed i waited so long now that industromart is not selling them anymore
          guess im gonna have to call AJ coleman which sucks because i dont have any part numbers to look at on their website....
          i want a adapter to run electric ell heads on my spartan cable this way i dont spend money on two sets of cutters.... one for my spartan 300 and other for drill and eel only (trying to save some money this way)
          want a good spade head
          want a root cutter 3'',4''
          want a sludge buster 3'',4''
          and want a 4x6 cutter for finishing lines
          also want that 12'' spring leader with spade head it think?
          want all 1.25'' cable
          want 2-4' sections
          want 15-8' footers
          want 1- 10' footer to drop in the roof first to get down the vent stack and then run the 8' from there
          also want the adapter thingy to make it work in my SUPER HOLE HAWG
          and 2 to 3 motorcycle tires or has anyone used/ or use the electric eel rels or whatever ?
          and anyone know those part numbers for what i listed?
            Re: drill and eel
            You don't need part numbers with AJ Coleman. Talk to Marv, he's probably got every part number memorized.
              Re: drill and eel
              want 2-4' sections
              want 15-8' footers
              Drill & Eel isn't any quicker or cleaner than running your drum but it does get the job done sometimes even going where other machines can't
              What size cable are you running in your 300 ?
              PM me your e-mail address I'll send you the Eel catalog in PDF format.
              I use Eel cages & rear motorcycle tires, very stable.
                Re: drill and eel
                running .55 in my 300 machine just got it actually form our spartan rep the sparshine sh1t or whatever.. like that cable alot and saw our fyasko about the breaking and flipping such a bummer man!
                pm sent
                • #23
                  Re: drill and eel
                  pm sent
                  Not sure if I'd want to run the beefy/heavy Eel cutters with the .55 ???
                  I also couldn't find anybody that offered the adapter for the .55 to Eel and I had called several places.
                  • #24
                    Re: drill and eel
                    They have it from .66 to 3/4 to eel but was told not to use it unless it was a straight run due to all of those fittings so close together.....I called AJ Coleman. They did recommend the 3/4 to eel adapter.
                    AllurePlumbing.com
                    • leak detection
                    • drain cleaning
                    • utility locating
                    • conductor fault locating
                    • and other specialties.
                    • #25
                      Re: drill and eel
                      only head i would use i probally the 12'' spring leader with spade head or whatever it is.... POSSIBLY a 3'' root saw at times as well as the sludge pusher i couldnt see those being a problem considering spartan offers the same style heads for the .55 but there heads and cutters arent as nice as the eel's
                      and hey asstyme 5/8 is the same as .55 isnt it if so this adapter is right up our alley SP-43 the spartan pin lock for the cable and eel's dual tool adapter chingas
                      • #26
                        Re: drill and eel
                        5/8'' = .625'' compared to your .55'' which is slightly larger than 1/2''. i wouldn't use anything big on a .55'' cable.
                        adapters just make the connections longer and therefore create a larger bend radius. wye's are not the issue. it's the 90's
                        • #27
                          Re: drill and eel
                          The Spartan .55 and 5/8" pin lock connectors are different. Most Eel cutters are very heavy I'm not sure I'd want to use them on anything smaller than .66 or 3/4".
                          The 1" wide pear cutters work best with the .55.
                          • #28
                            Re: drill and eel
                            what holder have you settled with?
                            AllurePlumbing.com
                            • leak detection
                            • drain cleaning
                            • utility locating
                            • #29
                              Re: drill and eel
                              The only one that's designed to hold the pair cutters is the brass style.
                              LARGE BRASS HOLDER
                              • #30
                                Re: drill and eel
                                I have some flat bottom offsets and they do not make a specific holder but have been told by others it will be fine. I thought that was what you were referring to.
                                AllurePlumbing.com
                                • leak detection
                                • drain cleaning
                                • utility locating
