Sink trap blown apart
  • Sink trap blown apart
    2 Pedestal sinks. Slow gurgling, branches loaded with hair. Took of the trap for the 1st one, got Lazy on the 2 nd. Using a Lil drop bulb I blew apart the old plastic trap.
    Didn,t charge them for My time fetching one, What is the largest size cutter You run down a lav sink? Would You have charged for the new trap? Thanks
    Re: Sink trap blown apart
    This was a 1 1/4" or 1 1/2" trap ? I would have used a 1/4" hollow core cable with a Ridgid style bulb head. Have to be careful rodding through traps as some of the metal ones are very thin/rusted on the bottom and too stiff of cable can break a plastic one.
    Charge for the trap ? Depends on who it was, lol !!!
      I would take off the trap.
        Thanks,Lesson learned. Can use a larger cutter on the 1 1/2" san tee vrs. 1 1/4"
          on a pedestal sink, there are times you can't even get to the slip joint nut to remove or replace. it's just a gamble to snake. i use 5/16'' hollow core to ease my way through.
          removing the trap on a pedestal sink is not fun as there are times you need to loosen the wall anchors to tilt the sink up and move the pedestal leg.
            If the trap was in good working order it could of handled being rodded through. So yes I would of charged for a new trap.
              This also depends on which size/type cable you're going to try & stuff down it
                Re: Sink trap blown apart ME BAD SEWER MONKEY
                Too lazy to change the drum on My super VEE. I'm embarrassed to admit I used 3/8"
                cable. Please keep this to Yourself, Friend.
                  ^^^^holy cow ....3/8 huh? f it go big or break sh*t lol
                    Originally posted by matt t service and repair View Post
                    ^^^^holy cow ....3/8 huh? F it go big or break sh*t lol
                    katman your thw balzz, love it !
                      Just oversize on the cables. 28 Years ago My bride was 118 Lbs.at the alter. Beth is still 118 lbs. Once in a blue Moon
                      [ last Sun ] I bought Her favorite " Carrot Cake"
