K50 Forget the mortar pan
  • K50 Forget the mortar pan
ID:	635421Click image for larger version
    So here's my new contraption. It's a 8$ oil pan with a cutout and a 1 1/2 electrical 45 in there. Used it on 4 jobs and really like it better then the mortar pan. You make the conections in the pan. So if you make your own, learn from my mistakes and:
    -insert the elbow close to the handle, this way if you pick it up by the handle, nothing drips out.
    -use a guide hose only 4 long.
    Total cost was under 15$ to make.
    Re: K50 Forget the mortar pan
    looks like a nice set up,
      It looks like a primitive drum machine.
      Just have to figure out how to better attach that oil pan (drum) to the machine
        I like it. Looks like a good idea!
          you just impressed me ben
          i like it. of course that's just for indoor work for me. not outdoor.
          so the late night phone calls and you never spilled the beans
            A lot to be said for squid ingenuity.
            I love it.
              I love it.
              But the term squid is usually reserved for surface warfare sailors,
              Ben is a Seabee and most (but not all) Bees have shore billets.
              And there is nobody better at scrounging or MacGyvering something
              together in a pinch when you need it most than a Seabee.
                Just a few more modifications and you will have a one piece drum machine
                  Nice set up. Almost as convenient as my Model N, which holds 75' of that sectional cable with in it's drum.
                  Do you have to hook up each section of cable one at a time? Just trying to figure out how you keep the cable under control while in use.
                  Will Rogers Plumbing
                  Moore, Oklahoma
                  405) 323-2852
                  www.willrogersplumbing.com
                    Hook up one at a time. The lip on the pan keeps the cable inside very well. If the model n had instant start/stop, it would be the ultimate.
                      Congratulations on creating the world's first sectional drum machine! This ends all the debates on which one is better.
