Root Ranger
  • Root Ranger
    I think I am beating this to death, I apologize, but I have some more questions. Just got it in today and I noticed it says not to get it up over 3000 psi. Is it just the Turbo Nozzle that cannot handle the pressure? I thought the Australians were using it with 4000-5000 psi?
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
    Re: Root Ranger
    Its a dud...
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
      Re: Root Ranger
      i run all of mine at 4000-4300 at the pump. by the time it gets to the nozzle from the several hundred feet of hose i might be running it will drop 300-1000# from the pump. of course the hose length and hose diameter is the key factor.
      keeping the hose length as short as possible and running 3/8'' will increase the performance.
      what are the machine and hose specs?
        Re: Root Ranger
        I have yet to get the stats at the nozzle, the hose just came in. The machine is 5.5 gpm @ 4000 psi at the pump with 200' of 3/8" hose.
        AllurePlumbing.com
        • leak detection
        • drain cleaning
        • utility locating
          Re: Root Ranger
          it should work very very good at those numbers. in fact the nozzle will not need all 5.5 gpm since it's most likely a 4.5 nozzle. your loss should be approx 1.25# per foot at 5.5 gpm. or approx 250# for the 200' hose.
          a simple test is to run the 200' of hose and see what the back pressure is on the gage with no nozzle. should be around 250#.
            Re: Root Ranger
            just looked at the ridgid page for the root ranger. Root RangerĀ® 3000 - RIDGID Professional Tools
            they probably state 3000# as that's all thier machines will produce. the kj-3000 and 3100 are the 2 units this nozzle was marketed for.
            the only difference between the australian version and the us version is the pipe thread and name engraved into it.
              Re: Root Ranger
              Thanks. Gear told me what to put together to get my numbers at the end also. Need to send my RR back due to a crack in the casting. From a different thread that I read a while back I knew what it was.
              AllurePlumbing.com
              • leak detection
              • drain cleaning
              • utility locating
                Re: Root Ranger
                my machine is just about the same specs
                the root ranger kills roots with those specs...had the same ranger for 3 years now still working and kicking butt !
                  Re: Root Ranger
                  Ok, so my machine is putting out 3900 psi at the end of the hose. I need to get a leader to go from my
                  3/8" MIP threads of my hose to the root ranger. I had one sent to me but the 3/8" FIP was a swivel connector and I can't see working the root ranger with it.
                  AllurePlumbing.com
                  • leak detection
                  • drain cleaning
                  • utility locating
                    Re: Root Ranger
                    It'll work. The swivel connector won't swivel anymore once you tightened it down.
                      Re: Root Ranger
                      actually that's the best way to go.
                      i just used my double barrel rr yesterday with 1/2'' hose and a 1/2'' fip swivel to 3/8'' mip.
                      leave you adapter screwed into the rr and then when it comes time to use, it's a fast and simple connection. when finished, add a little stem grease to the swivel threads so it never rusts and is a simple hand snug plus a turn with a crescent wrench.
                      did you love the root ranger?
                        Re: Root Ranger
                        I haven't even had a moment to put it together with the business taking off. I have a job lined up though.
                        AllurePlumbing.com
                        • leak detection
                        • drain cleaning
                        • utility locating
