Root cutter for 2"
  • Root cutter for 2"
    Been getting quite a few call lately for 2" drains and it ends up being roots. I was looking at the T-207 spiral cutter for the k50. What cutter or thoughts do you have on a good root remover?
    Re: Root cutter for 2"
    that works along with the 4 blade serrated spade and the never fails rick reverse auger with a good 45 bend and sharp grind. as long as there is a decent root ball, the auger will thread it's way into it. a few strands and nothing but a jetter will work.
      How do you think a 1/8 jetter nozzle will cut roots with 2 jets?
        1/8'' hose is pretty restrictive. 2 rears are out of balance and would require a lot of twisting. a good 1/4'' flexible hose should work with 3-4 rears. i would cable first and if needed jet what's left.
          I don't have the experience of You pros , but 4" terra cotter are the roots here. and only outside the foundation. Inside the Found. foot print, 2 " C.I. ,OR Galvy are protected .
            Yup, you're right but the roots are still busting through. Here's a pic where you can see the roots growing from the branch line. For this job after talking to Dan Lawrence, I applied rootX to the fixtures using a bucket of water instead of the faucet to flush the chemical past the ptrap. I'm going back to reinspect after 6 months.
              yup, you're right but the roots are still busting through. Here's a pic where you can see the roots growing from the branch line. For this job after talking to dan lawrence, i applied rootx to the fixtures using a bucket of water instead of the faucet to flush the chemical past the ptrap. I'm going back to reinspect after 6 months.
              c i ,hub ?
                yes from what I can tell.
