VIDEO Homemade super plunger RESULTS
  • VIDEO Homemade super plunger RESULTS
    Re: VIDEO Homemade super plunger RESULTS
    "That'll be $100.00. Now clean this up and make me a sandwich."
      Works as good as a Ro-Pump. One hint that the Ro-Pump has is fill the tube with water then make the seal and give it a push.
        where do you fill it up at?
          Better yet....God forbid the clog doesn't get blasted out of the toilet, where is all that extra water going to go?
          AllurePlumbing.com
          • leak detection
          • drain cleaning
          • utility locating
          • conductor fault locating
          • and other specialties.
            thanks ben
            i was just in the middle of eating a slice of apple pie and then you added dessert
            you're lucky all that joey asked me to do was turn down the volume she didn't see the dirty toilet
              You put it in the bowl, but do not make a seal with it yet, pull back the plunger to fill it with the water thats already backed up, then make the seal and give a hard push.
                I dont see how the fernco would make a tight enough seal in the bowl. If the stoppage is past the flange wouldn't it blow the seal? The six foot closet auger does wonders for me.
                  Bill, the fernco has quite a bit of flex. look and listen to the video very carefully. You can hear when I pushed the stoppage but the water never dropped until I moved the plunger. I like an auger too, but not when the bowl is full. I've scratched the porcelin because I couldn't see where to place the snake. I know you got way more experience and that probably negates the scratching but I don't want to take the chance.
                    Do you have any test video before the success
                      this homemade plunger is awesome. I saw the first post on this. any chance you can post the materials used to make this glorious creation? esp. the piston assembly...
                        Thanks for the Video. I guess? I am glad its not smell a vision. That one looked bad.
                        "don't put that in your mouth, you don't know where it's been"
