K-60 Drain Machine Repair
  • K-60 Drain Machine Repair
    Here is a job I just finished up. The K-60 was locked up I determined that the problem was one of the bearings was frozen tight. Took it apart removed the bearings (I replace both of them). Pressed in some new water resistant bearings that I have had good success with, bolted everything back together and with some minor adjustments the machine is back in service.....
    Nose cone and drive gear removed..
    Bearing was frozen tight...
    Machine taken apart.
    New bearing pressed and installed in drive gear..
    Drive gear reinstalled
    Front bearing installed in nose cone.
    All bolted back together ready for work...
    Re: K-60 Drain Machine Repair
    had a similar write up a couple years ago.
    but of course trying to do a simple search was not happening as the search feature is a waste of time on the forum. so i had to review over 1000 photos of mine to find the thread.
    " i lost my balls " https://www.ridgidforum.com/forum/t32278/
      Use google to search ridgid forum. https://www.google.com/#hl=en&safe=o...w=1280&bih=642
        Well I apologize for the repeat subject post. I did not know another one existed.
        The main thing is, there is help here on the forums for those that need it..
          nothing to apologize for
          in fact thanks for taking the time and effort to post and document the steps and photos for the k60 repair.
          nice to have another welder/ plumber on the forum to share their knowledge with all of us. wait til "tool" finds out their's another welder to play with.
          welcome
            Thanks Rick for the welcome.
            I like sharing info, and as you well know the info that is only learned by experience is what matters. Don't get me wrong "book" knowledge is good but it only heads you in the right direction, before experience takes over..
            "Wisdom is to know how to use the knowledge you have learned".
            Does age come with wisdom? or does wisdom come with age?
            We all have something to offer, we all have our God given talents. I think we start to have problems when we get out of out "talent range"..
