Double barrel root ranger + 1 more?
  • Double barrel root ranger + 1 more?
    Hi all! I have a 3000 gpm 4 gal/min General cart jetter that I looking to maximize the effectiveness of, as a trailer jetter is not in my immediate future. I am running 3/8" hose and I have a warthog, single barrel rr, penetrator 3f/3r, and a variety of smaller nozzles.
    Question #1: Will a double barrel rr work on my machine (2 x .030's?)?
    #2: Does anyone know of any nozzle that will front cut as good as or better than warthog? Perhaps something smaller?
    Thanks!
    Re: Double barrel root ranger + 1 more?
    no, the double barrle root ranger is a mass of metal with twin turbines. 4 gpm is not enough to power the 2 turbines and pull the hose and the head.
    stick with your single rr as that will be much easier to pull and also flip as needed to get to the top of the pipe.
      ricks right
      my jetter is 5.5gpm @ 3500 psi.
      I have a double barrel rr and it works good in 4" pipe on roots... but 6" not so good it clears mud and grease very well. But for root cutting in 6" the single is bar none the best !
        warthog on 4 gpm.... that dont sound right?
          at first i thought the same thing. but i own a 1/4'' warthog that's a high speed spinner. not the oil filled controlled speed we think of.
          so yes, there is a 1/4'' warthog that will work with 4gpm at 3000.
          but my 1/4'' wathog at 4000 and 6 gpm was pretty much a waste of money. for 1/2 the price, a 1/4'' single barrel root ranger will run circles around that warthog and cut roots too.
            i too have a 1/4" warthog...its a waste of money...lol
            The rr cost less and works sooooo much better
              ricks right
              Which single do you like for 6"?
                for 6'' with a 4'' access or larger, the 1/2'' root ranger with 1/2'' hose will blast till you drop.
                ben, was it the 1/2'' root ranger or warthog that i wore you out with while trying to pull back under pressure
                honestly a 1/4'' root ranger with a good idea of where the roots are will clean out just about any size roots. maybe i'll post my 2x4 i cut with the turbine nozzle.
                or the hamburger meat i made of 2 fingers with a turbine nozzle on my spray wand. in a split second with gloves on, i accidentally passed my left hand in front of the spray gun while washing the concrete with no wand extension. in that split second, my glove was torn off and my 2 finger felt like they were on fire. looked like hamburger meat and took several weeks to heal without oozing
                there is not much a root ranger can't clean. it's all in the design of the turbine.
                  Ben i use the 1/4" ridgid one....works flawlessly !
                    So you like the 1/4" one more the the double barrel ranger....interesting, what exactly makes the single barrel better for you?
                      With the single and only 3500 psi all your psi is focused on one barrel. Its like putting all your eggs in one basket
                      With the double and that low of psi it does not have the raw cutting power of the single in 6" . it does clear storm lines with no issues . In 4" the double works good on roots or whatever u got for it .
                      Im sure at 5k psi like bill runs the double would have no issues.
                      Its interesting. If you fire the double and single up out side the pipe the single sprays about 4 ft higher than the double.
                        What I find interesting is that nobody really talks about the 1/2" RR with any set up.
                        AllurePlumbing.com
                        • leak detection
                        • drain cleaning
                        • utility locating
                        • conductor fault locating
                        • and other specialties.
                          i've talked and posted pictures of the 1/2'' rr. but remember that not too many of us here have a 1/2'' hose reel / jetter that's putting out 18gpm at 4000#.
                            Without bashing the site directly, it is hard to find. It would also help if here were any info on the manufacturers website with the specs needed to run these nozzles effectively. Don't get me wrong, it is great to hear the real story in the field from people who use them.
                            AllurePlumbing.com
                            • leak detection
                            • drain cleaning
                            • utility locating
                              here's the thread i posted back in 2009 that caught your interest. https://www.ridgidforum.com/forum/t27280/
