double barrel root ranger
    Re: double barrel root ranger
    beween the guage on the pump and the reel guage is about 60ft of jumper hose.
    worked awesome on 4" with grease !
    The true test for the new dbrr is 6" with roots... with the other inserts its just didnt finish it off as well as the single did.
    Even with the single barrel the pump guage reads 3500 psi and the gauge on the real reads about 4000psi
      I would switch both gauges and see if you get the same reading, sounds like one of your gauges is bad.
