K39 Spares
  • K39 Spares
    Hi All
    How many K39 110v mavchines would you reckon are in the uk ?
    I need the cable gripper springs 68947 and a new trigger switch (No ref)
    Having tried my local dealer, it appears no-one in the uk carries spares, best estimate so far is 6 - 8 weeks delivery !!!!!
    I think that is a bit naff !
    Post some to me, I'll pay by visa
    Re: K39 Spares
    for the most part the cable grippers are useless. you would be better off converting it to the hand chuck. not only will the cable not slip, you can then feed to the very last millimeter
    the switch might be more fun as your's is most likely different than our 120 volt setup.
      Re: K39 Spares
      Thanks Rick
      Have now found a spring supplier, in stock, the chuck eould be far better as you suggest.
      Having taken the machine apart, found a wire out of the switch, switch is ok so saved me £50
      Have fun guys.
      John
