dead unloader
  • dead unloader
    cleaned several culverts 14" 16" full of rock & sludge. the engine started to bog down ,so i figured out the unloader had failed finished using the bypass valve to govern pressure. now i need a new un loader.11 gpm 2500 psi jetter i have seen prices from $89 to $485 how to chose & where to buy is my question Rick mentioned one but i couldn't find the reference .
    Re: dead unloader
    here is the one i run. have them also sell you an adjusting plastic knob. beats using a wrench on the factory hex nut.
    WEB ORDER FORM yu 2140 http://envirospec.com/bdown/1101.pdf
      Re: dead unloader
      will the 2140 adjust to 2000 -2500psi?
        Re: dead unloader
        of course. your specs are exactly as my first trailer jetter and it worked like a charm.
        the adjusting knob makes it easy to fine tune your #. you could also install a bypass valve and use that for the smaller nozzles and hoses. http://generalpump.com/PDFs/100814-%...le%20Valve.pdf
