rick reverse auger saves thanksgiving
    Re: rick reverse auger saves thanksgiving
    pretty much with an open hook heated and bent out.
    the key is that you have to run the motor in reverse to spin the cable counterclockwise. this will act as a corkscrew and thread it's way into the obstruction.
    a word of caution. when running in reverse/ counterclockwise, the cable will want to auto feed into the drain. can be useful, can be dangerous.
    the great thing though is that the sectional clutch will stop the cable instantly and prevent a knot
    unlike a drum where you might have a 100-200# flywheel of cable wanting to spin. especially with only a few feet of cable in the drain
      Good job.
      K50 is an awesome little machine.
      Are you using the oil drain pan to hold your cable vs the hose?
      i would have tried to sell stainless supply lines, don't care much for the rubber stuff.
      might even have tried to replace the boiler drains with ball valves-if the unit had an individual shut off.
        You are touching that cable with your bare hands,,,,,,, gross lol
          Originally posted by Gettinit View Post
          Hey, sup dat? Smile
            Originally posted by theplungerman View Post
            Hey, sup dat? Smile
            AllurePlumbing.com
            • leak detection
            • drain cleaning
            • utility locating
            • conductor fault locating
            • and other specialties.
              and his keys are laying in the bottom of the tray which he will then put in his pocket.
                Just before pickin' his nose and shakin' your hand...
                • #23
                  if you're. worried about the bare hands, then you'll be shocked by my plumbers milkshake.
                  and the cutter was a used 1
                  and this is what a 4.5m view looks like from the buildings roof.
                  • #24
                    Dude, I won't even change a diaper.
                    • #25
                      i guess you like grease and oil over pee and poop.
                      both of us are in need all the time. it's all bread and butter.
                      • #26
                        Melody at jm mckinney showed me your milkshake video. a used cable?,yuck. smile, my guy will pull a used wax ring off then eat a burger with the same hands. not me. i have been putting on surgical gloves when i pull up to the job for 10 plus years now. so wed when you show me more jetting tricks and let me buy you lunch ill show up wearing protection.
                        • #27
                          Melody at jm mckinney showed me your milkshake video. a used cable?,yuck. smile, my guy will pull a used wax ring off then eat a burger with the same hands. not me. i have been putting on surgical gloves when i pull up to the job for 10 plus years now. so wed when you show me more jetting tricks and let me buy you lunch ill show up wearing protection. :D
                          i'm not that type of guy
                          • #28
                            LOL - I too lost focus of the origin thread after seeing photos of the laundry room and hearing the price of the condo.
                            So what's the plumber's milkshake?
                            • #29
                              need to watch the 3 minute video.
                              where were you a few years back when i needed the extra votes
                              • #30
                                Sorry Rick
                                So where's the video?
