Ridgid Carbide Tip Tools
  • Ridgid Carbide Tip Tools
    http://www.ridgid.com/Download/K60Cables.pdf
    Shows "Carbide Tip Tools (For Cement Blockages)" We have a customer with underslab heating with concrete from the foundation pour completely blocking a 4" sewer line.
    This is affecting all plumbing on west side of home ~ there is a seperate stack for east side.
    Did an exhaustive search of the forum but did not see anyone that had experience with these tools to break up a solid concrete obstruction. This is not just some floor patch, tile grout or loose debris.
    Before I order and destroy these and charge out the better part of a day plus parts to our customer, can anyone actually say they've been able to get through a 3-month old solid concrete/gravel obstruction in a 4" lateral line using these.
    Thank you for your time and consideration.
    www.edmontonemergencyplumbing.ca, or visit us on https://www.facebook.com/#!/pages/Ed...61557037236080
    Re: Ridgid Carbide Tip Tools
    i'm going to say your only chance of cutting out the concrete is with a forward facing root ranger. if using this going upstream from the open end. need at least 3000 psi and a good 4 gpm or more.
    now if the sewer is plastic, you will probably destroy the plastic with the jet blast and sandy debris blowing off.
    any idea of the amount or distance of concrete.
      Locate, dig, fix, replace.
        ABS plastic. Could be as much as 9 ft of concrete, but difficult to be certain. This was at the bottom of the 90' where the vertical stack turned to make the lateral run from west-east side of the house ~ enough to plug the lateral and start coming up the vertical.
        Customer abandoned line and re-plumbed to adjacent area.
          9 feet or 9 inches of concrete, they made the right move to abandon the line.
          sure hope the homowner didn't eat the cost.
            No idea ~ we were brought in by the builder. Presumably builder or homeowner will approach whomever poured concrete for compensation.
              so what kind of concrete blackage would these carbide tipped heads work? any pix of them? occasionally i get a call for a blocked line where plasterers/tilers/etc have dumped slurry and other debris into a line blocking it. i've had minimal luck, at best, getting some of these open.
