How To Post Images
See more
See less
What Would You Get?
    Re: What Would You Get?
    Don't buy a thing...just keep using that I95 you got. If you really need to apply the torque, get a general innercore but that's all I'd do. If you have multiple lines to clean, make a 30' guide hose and just keep the cables connected. The 1-1/4 eel cable is great and physically easiest out of the drum or k60 or k50 but it takes a while, connecting those cables.
    Problem is the I95 will never be on this truck. So I need around 30' of controllable sections (no fifteen footers) and a drill setup. I do not want long sections at all. Doesn't have to be 1-1/4" cable. Could be 7/8". Just everyone's experience I've read about is with 1-1/4".
    Eel cables hard to connect and disconnect? I'm open to other decent cables with similar lengths (less than 10' and some short sections for control) but I do need a way to drive them in the drill.
      Then look at the electric eel J cable setup. They're hard to connect and disconnect when new.
        Very easy to connect/disconnect just spray some WD-40 on them once in awhile as they are a PITA when they start rusting.
          Ok. If I go with the J Cable, what's needed to drive it with a drill?
          Same shaft & coupling? SC-10, SC-12, RP316118.
          Or different?
            SC10 is for the 1-1/4...for the j cable it'll be different but I don't know it. I had my SC12 machined but I know rick used a simple bolt and roll pin.
              SJ-7 is the adapter for anyone's interest.
                Or different?
                Why not drive it with one of your handy hand spinners
                • #23
                  Those are too busy. Walking out with checks faster than others can decide which of their Ridgid K-Dumb pistol rodders to use.
                  • #24
                    K-Sissy, K-Stupid & now we have the K-Dumb
