Correct head for Ridgid K-400 (4" line)
  • Correct head for Ridgid K-400 (4" line)
    I need to snake out my sewer and based on how I'm going about it, will only be dealing with the 4" main line. I believe the clog is a combination of toilet paper and tree roots. Can someone suggest the best head to use with the K-400? I will be using a 1/2" cable. Thanks.
    Re: Correct head for Ridgid K-400 (4" line)
    You,re going after Bear with a 22 . Hit some roots and That 1/2 cable will look like corn rows !
      Save your self some frusteration and money either hire someone with a bigger machine or rent a bigger machine.
        A spiral saw is your most agressive cutter for roots. But as others have mentioned, you're taking a large risk with a small machine and cable.
        If you do run into resistance, take very little bites and make sure you can pull back the cable before you progress forward.
        A 4" line with roots requires a minimun 5 /8" cable and stronger machine. Sure an experianced fisherman can land a shark with a trout rod every now and then, but they also know when fishing for sharks, use the shark rod.
        Rick.
          Thanks for all the tips. I went ahead with what everyone suggested and rented a machine today. I think it was a 3/4" cable; regardless I cleared the blockage.
