Ridged K-3800 Drum Problem
  • Ridged K-3800 Drum Problem
    have a K-3800 with a problem
    The 3/8 cable has been riding up in front of the inner drum
    and tangling up so the cable will not come out or in.
    I can spin the inner drum and the outer drum to loosen the cable
    but this slows down the job considerably.
    I have pushed the cable into the drum without it spinning so that it sits
    properly in the back of the drum but as soon as I start feeding out it tangles.
    This is a new cable properly installed.
    Any ideas?
    Thank you
    Re: Ridged K-3800 Drum Problem
    Disclaimer- I have not used this machine.
    Can you pull the cable all the way out of the drum and check it for kinks before feeding back in with some oil to lubricate the cable? Beyond that, it may be machine related.
      Also have you made sure that the cable is being loaded in the correct orientation? and what size cable and how many feet?
      Derek
        And the machine is spinning in the right direction
          Thank you for your responses.
          I'm running 50' of 3/8 My Tana hollow core in pristine condition. All set up properly.
          Brought the machine in overnight and it seems to be working properly.
          My conclusion is a new cable with the sub zero temps of late not wanting to do
          what I want in the drum. Time will tell but we have another cold snap tomorrow.
          Thanks again
            What is a " cold snap" in Minnesota? -25 degrees?
            You are probably correct, cold does lots of funny, unexplainable things to mechanical/electrical products. Especially during a cold snap!!
