Cable cleaning
  • Cable cleaning
    What are you guys using to clean your cables?
    I get sick and tired of having a tug of war with my K-50, and sick and tired of buying new cables all the time.
    Re: Cable cleaning
    Not sure what you mean. Only the greasy kitchen lines are an issue with no running water. Usually running a garden hose on the cables will wash them off if they're greasy. Even some simple green.
    Why all the new cables? Are they not 5/8" sectional cables, but drum cables for the drum adapter?
    Rick.
      Re: Cable cleaning
      Rick.
      I should of been more specific, I'm talking about the 5/16th or 3/8th cable for drum adapter.
      I have no kinks on my cables, but there will come a point in where on the 3rd or4 pull, it gets stuck, and I have to pull so damn hard or push it back in then start again.
      I've tried scrubbing them iwith a hard bristle brush and hot soapy water, but doesn't take long to go back to being rusty.
        Re: Cable cleaning
        Personally , I don't use the drum adapters. I use the k39 and remove the cables when they are wet. Takes seconds to shake dry and store. I only use the k50 for 5/8" sections.
        Rick.
          Re: Cable cleaning
          Yea, my 5/8" cables are fine, it's the smaller ones that give me fits.
            Re: Cable cleaning
            Chlorides in the soap, chlorine in the water. Try keeping your cable in a 12" and/or 20" Bicyle tire. Use something to protect the metal.
              Re: Cable cleaning
              When ever i get the chance i wash my 5/16 cable in the drain with what ever good stuff the customer has in the cabinet , its always clean
                Re: Cable cleaning
                I must be lucky. I left a Ridgid 3/8" cable in the drum of my K-40 for about a week before I needed it again and it looked brand new still, no rust.
                AllurePlumbing.com
                • leak detection
                • drain cleaning
                • utility locating
                • conductor fault locating
                • and other specialties.
                  Re: Cable cleaning
                  Take them out and clean the cables with a pressure washer. Put them in an oil pan with some wd40...next time you use them, do what Rick suggested with taking them out the drum.
