Small Jetter
  • Small Jetter
    I have a gas powered pressure washer I've converted into a jetter.I use it to clean out 4" storm drains to the street.It's 4 gpm and 3800 psi.Can a pulsation valve be installed to this?
    Re: Small Jetter
    Yes. Depending on your pump. Either a bypass valve can be plumbed into 1 of the inlet valves, or some pumps already have a pulsation valve available that just replaces a valve cap.
    A fast acting foot valve or spary gun will usually work as good or better than a pulsation valve.
    Rick.
      Re: Small Jetter
      Thanks Rick.Sounds like the foot valve is easier to install.Any suggestions on such?
        Re: Small Jetter
        Ridgid makes a foot valve. I think its a fv1?. Or just try the spray wand for a quick sample.
        Rick.
          Re: Small Jetter
          Suttner makes the other one. Don't need a pulsation valve. Post some pics of your jetter and we'll help you out with what you need. My jetter is almost at the same specs as yours.
