Once again, best toilet auger please
  • #46
    Re: Once again, best toilet auger please
    Well ,I am impressed with the new general drop head auger. Great engineering and quality. The No Workey buttons, on My old ridgid , gave Me fits !!
    • #47
      I prefer 6' Drop Head or Regular Head general auger. It is the finest drain cleaning product.
      • #48
        The New K6 is a different animal , Much improved !
        • #49
          OK, my take on the new drop head auger. The ergonomic grip is a waste. I didn't care for it but did not cause any issues at all. I like the large end of the handle. This is where I grip mine. The only thing that would make it better for me would be a swivel ball at the end. I think the business end should be a little smaller in diameter due to some of the cheaper toilets and the narrow passage ways. Thank you for doing a better job with the retaining clip that holds the auger when you are done with it.
          The only real issue I have with it is that the cable, when caught on something, comes out of the shaft. I put it back together more than once to make sure I wasn't just in a rush and didn't let it snap into place. Although it will not be a normal issue it does concern me that if all 6 feet were out it could be lost into the toilet requiring me to pull the toilet. On one hand, it may have to be pulled anyway. But, I also like to use a dedicated auger for floor sinks. What an aggravation that could be.
          All in all I liked the newer version.
          AllurePlumbing.com
          • leak detection
          • drain cleaning
          • utility locating
          • conductor fault locating
          • and other specialties.
          • #50
            I'm disappointed they don't make a 3' drophead
            I only use a 6' when needed as they have a totally different feel and are heavier. I open 95% of toilets with a 3' and prefer them.
            • #51
              I am loving the new 6' drop head auger. All I use now. I always run out the 6' just to be sure.
              • #52
                Used my new 6' Ridgid auger yesterday, paid for itself and then some.
                it's a bit cumbersome getting the last three feet back in and getting the button to pop.
                Haven't seen the drop head yet
                • #53
                  Pull the cable out of the tube, and lube up the inside with a good silicone grease and the part that slides in the tube lube up good. This helps a whole lot.
