Flat Tapes
  • Flat Tapes
    Do you still use use them ?
    Carry such in your service truck ?
    Last,what do you think of them ?
    Re: Flat Tapes
    I just charged a guy a Little over a thousand $$$$ for using one to much
      Re: Flat Tapes
      have one. the father in law uses it. if all of the other machines are broken and you like looking like a fool, then that's the one to use.
        Re: Flat Tapes
        When you are off the grid then it's the only thing we have to clear a stoppage. Only usable in straight pipe with a cleanout access. Closet bends are a problem. Good for soft stoppages and bottles jammed in the pipe.
          Re: Flat Tapes
          Why the interest........... ?
            Re: Flat Tapes
            I have a sink tape and the heavier General main tape you get at the supply house. The city guys have a really heavy tape with a large ball. I use it mostly for locating sewers. If its a PVC line I have also used a tape before running a camera when I was not near power.
            AllurePlumbing.com
            • leak detection
            • drain cleaning
            • utility locating
            • conductor fault locating
            • and other specialties.
              Re: Flat Tapes
              I keep one on the truck, just have not used it for a very long time.
                Re: Flat Tapes
                Thinking of becoming more proficient with flat tapes in times of disaster,and if servicing someone who is off grid and a jetter is not useable.
                  Re: Flat Tapes
                  I am saving up for a Honda inverter generator. Small, light, can run in tandem and gas efficient.
                  AllurePlumbing.com
                  • leak detection
                  • drain cleaning
                  • utility locating
                    Re: Flat Tapes
                    What if no fuel is available?-------------The Honda generator seems to be very good,what wattage would be your minimun?
                      Re: Flat Tapes
                      Look into them. I think 1/2 a gallon will run all day. If there is a possibility you may need it I am sure you will run by a gas station if you need gas. I don't know what you may need it for so I am not sure. I was looking at the 2000 watt unit. Maybe plan the trip a little better and ask some extra questions before heading out. I would ask about where the cleanout is and if the have outside faucets. Maybe a nice neighbor wouldn't mind letting you use water.
                      AllurePlumbing.com
                      • leak detection
                      • drain cleaning
                      • utility locating
                        Re: Flat Tapes
                        I was thinking 3500 watts to run a K-1500,most of the problems with capped hose bibs are at apartment bldgs,and there is often no time plan the trip.
                          Re: Flat Tapes
                          Just when you think your disaster can't possibly get any worse, the tape snake can prove you wrong.
                            Re: Flat Tapes
                            It seems as if you has had to wrestle a few free from roof vents or cleanouts.
                              Re: Flat Tapes
                              Does anyone else tape the ball at the end?
                              AllurePlumbing.com
                              • leak detection
                              • drain cleaning
                              • utility locating
