my catch of the year
  • my catch of the year
    had a very interesting one today on a bathtub drain.
    large beverly hills home, upper daughters bathroom. kohler trip pop up missing along with the linkage. no grid strainer to prevent anything from falling into tub shoe.
    snake from the removed trip lever with my k-39 and line is draining decent. then snake the shoe to remove a plastic shaver blade cover. then the tub stops draining completely
    try from the overflow and my cable keeps going out the shoe. couldn't get it to go down and water is standing still. put my micro explorer into the overflow and the drain was blocked right below the shoe with what looks like a cap to a bottle. had the owner look at the camera and she couldn't picture what the daughter could have dropped in. no access panel and i'm thinking if i can spear the cap if it's plastic.
    didn't have my flexible drill bit with me to drill and grab it. so instead i thought of using my wire stake sewer flags and bending a small hook into it. then heat it up with my torch and try to melt through it to snag it
    the owner was looking on and not only did i snag it the first attempt. it turned out to be a little bottle they use for makeup samples. the wire actually welded itself into the bottle and it came out without an issue.
    glad it wasn't made of glass.
    there is now a strainer sitting in the drain shoe.
    kohler pop up that was missing along with the linkage. the overflow plate didn't have the lingage attached to it.
    makeup bottle i snagged with a hot wire hook.
    wire welded to the bottle.
    the rest of the collection.
    Re: my catch of the year
    That's an impressive snag. Great job.
      Was the drain made of metal, abs or pvc
      Great Job
        brass. i would have been out of luck with plastic.
          Thinking out of the box like that is what makes you successful.
            Creative thinking
            Do you think a RoPump would have had any success ?
            I sucked this baby (along with a wad of hair) out of a bathroom tub. Sucked it up 12" vertically it was caught at a 90.
              That thing really sucks.
              Where, in the U.S. can one purchase a Ropump.
                Bought mine from eBay Europe around 2 years ago.
                Member indeepinchicago has recently bought one from the states at:
                Allied Plumbing Supply
                6949 W. Irving Park Road
                Chicago,IL. 60634
                773-545-5492
                Speak to Dan, he has knowledge of what the "Ropump Superplus" is, the model number is "72070X"
                  How in the world did that makeup bottle make it down the drain? Was it the same od as the id of the drain? Do you think somebody put it in there on purpose?
                    Chicago,IL. 60634
                    773-545-5492
                    Will contact.
                    Thanks
                      i had a similar experience a few months ago same kohler tub drain,linkage removed along with the pop-up,nothing to stop large objects from entering drain. could not get it open with milwaukee drill snake. had to cut access panel in kithen ceiling,could not get at trap from second floor. Removed trap ,,,,red brass with union,,,looked down 1 1/2 galvanized pipe and saw something pinned against 45 degree ell about 14 inches downsteam, could not get the object to move with snake,,,,,,had an 18 inch x 1/2 inch drill bit on the truck ,,,,,hand threaded into the drain pipe and came back with a shampoo bottle cap,,,,,,,they now have a stainer in their bathtub drain,,,,,,,,,,,,
                        i wonder if a good wet vac would work,,,,,,,,,$200 bucks for a hand suction gun rothenberg ropump seems a bit price-ee,,,,,,but so is a vacuum,,,,,,,,ill bet it is very handy tool
                          That is Amazing !
                            that was my next thought. would need a pretty flexible hose to get down the overflow. have used them in shower drains.
                              Try a cut down garbage disposal adapter or one of those hacka-flex-ptrap adapters, they should fit to the end of your vac hose with little effort.
