Had A Call Back Last Month..........
    Re: Had A Call Back Last Month..........
    Originally posted by BHD View Post
    IF you feed them back to the chickens it helps them in there calcium needs, and helps them with producing better or stronger egg shells, and that way you do not need to buy oyster shell for them,
    only if you crush and dry them otherwise they will start eating there eggs.
    the only dumb question is the one that is not asked!
      Do you not have a Sludge Buster/Pusher? Would have made quick work of that. Run alot a of water behind it, run it through a few times, then finish it off with the expanding cutter.
      Will Rogers Plumbing
      Moore, Oklahoma
      405) 323-2852
      www.willrogersplumbing.com
        Yes I do but it was a 3" line and the cleanout was on a vertical. My 2 7/8" (actual size) sludge pusher would have never made the corner.
          Make you one of these with a worn cable.
          Moore, Oklahoma
          405) 323-2852
            Yes that's exactly what my first 8' section looks like except it has the end connector.
            After 1 1/2 years it's getting pretty thin at the bend about time to throw it out.
