snake oil
  • snake oil
    what are you using on your cables to oil them. i have always used ridgid snake oil. but would like a cheaper way. i also have one that i found in a box that that had got wet from melting snow etc and the first 2 feet of the cable are rusty.
    i was thinking of just car oil. and for the rusty one soak it in car oil. 5 gal bucket.
    what do you think?
    the only dumb question is the one that is not asked!
    Re: snake oil
    I've tried atf. It's light weight oil. Also marvel mystery oil, but I think its more than snake oil.
    Even tried diesel fuel.
    The real trick is to not let you cables sit in water or the wet drum.
    Rick.
      Re: snake oil
      Get enough work and you don't need to worry about your cables rusting The only thing I oil with WD-40 are the ends of my Eel 1.25" cables & my specialty cables such as my Ridgid 5/16" drop head that doesn't get much use.
        Re: snake oil
        My father used to use used motor oil. He put it in an oiler can, and oil up his cable weekly. I spray mine down with WD 40 after each job.
