Australian jetting question
  • Australian jetting question
    Re: Australian jetting question
    Hi Gear Junkie
    Most of the lines I clear are root blockages, have never really come across any major grease problems, most of the plumbing systems have grease traps on them before the waste heads into the drain so maybe that helps, could also be the temperature over here the grease might not get time to set in the drain, not sure about the bigger lines most of our drains that I work with are only 150 mm and I do a fair bit for the water board around here
