General 4" Heavy Duty Side Cutter Blades #L-4HDSC....
  • #46
    Re: General 4" Heavy Duty Side Cutter Blades #L-4HDSC....
    Originally posted by Swade Plumbing View Post
    I talked to Marvin at AJ Coleman today. He said that using the General L-CA adapter with the clog chopper is not a good idea as there is too much play in slotted connector.
    I bought a 3" chopper today. I'll try it out tomorrow on a 6" line with some roots.
    I also bought some eel cable, but it turns out that I CANNOT use it in my R750 as the cables are just a little too big and do not fit past the jaws. Apparently the Rothenberger cables are just a smidge smaller as they are metric. The ridgid cables work in the R750, but not the general or eel L cables. I'm pretty peeved.
    It seems all the General bit connections are sloppier than a.... uhm.......... you know..........
    • #47
      Actually the 4" hd blade would be worse as its more of a hole saw and doesn't have any play.
      The standard 4" spiral saw is the best as it has more of a running spiral and will navigate the 4" bends. Its designed as a double blade side by side. Although I usually run just 1 saw blade. Forward cuts and reverse tears and rips.
      Use my 3" or 4" as my first cutter everytime in a 3" or 4" cleanout. 2" and smaller get my reverse auger.
      Rick.
      The General 4" bit is actually 3.5". What it the actual diameter of the 3" ?
      • #48
        Originally posted by rod man View Post
        These blades are 4sc blades not 4hdsc blades. The hdsc blades are 1 piece and go with a allen head screw in the center of the coupling marvin
        Received the correct one today it measures 3.5" across. The blade looks ok but I don't really care for the long stiff section could be a problem around 90's ???
        • #49
          Interesting thread to be sure. I agree those general 2 piece cutters are not so good. I adapted my drum machine to use them because all plumbing supply houses have the blades. it seems the 4 inch blade worked good in 3 inch but they were to loose in 4 inch and really were bad in 6'' clay. I can only get to most of my clay by going through 10 or 20 feet of 4inch cast. Any how I got a few call backs using the general cutters. so I stopped.
          I'm surprised you guys use root saws and all that they always seemed gimmicky to me and Heaven help you if get stuck in a wye with that heavy duty general root saw.
          I thought most of you started with as big a blade as you could get down the clean out? heck I want to get the drain opened up and cleared as good as can be on the first pass, most times I can.
          I hate having to go in with small cutters to start.
          • #50
            This is a l-ca cutter adapter with a general adapter on it. The l-ca adapter is threaded in the center and the blade goes on without the general adapter. Somebody does not lnow what they are selling marvin
            • #51
              Didn't look right to me either.
              • #52
                I should have figured that out
                ThanX Marvin
                • #53
                  Ahh yes !!!
                  Me so very much happy now
