Another Sectional Option In My Arsenal........
    Re: Another Sectional Option In My Arsenal........
    Just bought some General 6' x 7/8" and a 1.25" to 7/8" cable adapter to go with the Eel 7/8" I had. Now I just need the adapter to run the 1.25" bits should be here soon
      Azz, I'm starting to think your a tool Whore
        That corn is about ready
        26+6=1
          No not really I just like to try a few new things now & then.
          If I don't think I'll ever use them or don't like them I move them out the door
            All of my 7/8" "J cables" are a PITA to connect as the pin seems too long/not rounded at the top. Is anyone else having the sames issues ?
            I took a dremel to my Eel J cables and rounded to pin now they are smooth will have to do the same to the General cables.
              Yup, pretty soon all you'll be seeing is the tail light of my sled fading off into the distance
                It is a snug fit. Might do the same.
                • #23
                  The J Cable are harder to hook up, but haven't been that big of a deal to me
                  Will Rogers Plumbing
                  Moore, Oklahoma
                  405) 323-2852
                  www.willrogersplumbing.com
                  • #24
                    Some were OK and some were almost impossible to connect. After a little work they are now all smooth.
                    • #25
                      Are you using gloves? I guess since I don't it's not to bad to hook up. I don't use the J Cable a whole lot so mine get stiff from not being used everyday.
                      Moore, Oklahoma
                      405) 323-2852
                      • #26
                        Yes I always wear two pairs of gloves.
                        Hope you are up to date on your shots
                        Just received the Eel 7/8" to 1.25" adapter today. Same thing, the pin is too long & dished in on top had to grind it to a dome.
                        • #27
                          The missing link finally arrived
