When..........
    Re: When..........
    Help me out. What is the purpose of a chucked pistol grip machine? How does the chuck help?
      Re: When..........
      The slide chuck is kinda useless when trying to navigate old 1.5" and 2" galvanized or CI drainage fittings. They are short sweep (basically pressure fittings) and a PITA to get past. The chuck keeps the cable locked in place so that you can build up a little more torque to spring the cable through the bend.
        Re: When..........
        My slide chuck on my K45 seems to work fine on galvanized and CI fittings so far of maybe I've been lucky so far.
        I'm loving the self feed over my old super-vee arm killer.
        Rod
        http://unclognh.com
          Re: When..........
          Like I said it would only be for the few each year that I run across. I recently bought an Eel Model S, haven't used it yet but it pains me just to look at it
