chain flail rootrattype nozzles to descale
  • chain flail rootrattype nozzles to descale
    I have 3 or more bigger jet and descale jobs coming up.
    One is 4” 100+ foot run commercial
    One 75 or so residential
    I have a warthog but I think a chain flail or root rat wouldwork much better?
    I have some question?
    Both jobs require jetting from upstream to down stream
    The wart hog seems to do and ok job but not great at myspecs 12 GPM 3000 PSI
    What is a good nozzle to purchase and pros and cons.
    As for getting the scale out I was thinking of trying theturbo nozzle on the end and using a fiber glass push rod to help push the scaledown stream.
    and any other help would be great.
    i have done 30 or so lines with the wart hog some
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
    Re: chain flail rootrattype nozzles to descale
    Root rat should be good and your specs should run it no problem. There's a youtube video of it cutting down a cinder block. Redwood has the rrot rat and can give specific details on it. The turbo nozzle taped forward will definitely push everything downstream. Ever thought about using a root ranger?
      Yes and I have but all the sewers around here need to be done from upstream to city connection
      Appleton WI, 54915
      1-920-284-7471
        You got a ranger? Use the ranger to descale the pipe then go in with the foward rotor/push rod and push all the scale downstream. Do that all the time.
