  • 1500
    Has anybody ever stalled out a K1500 in a sewer? Had 15' section that just stalled it out and then it was clear sailing. The sewer was full of feminine products and grease.
    Re: 1500
    they make a 1hp hd model that should turn a cable into a pretzel. could be a long power cord, voltage drop too.
    at the roundup we drilled 3/4'' pine approx 3'' hole and the 3/4 hp machine would stall if loaded up. could also be the clutch is slipping and motor is still running.
      Re: 1500
      i've had it stall before. a short, heavy gauge extension cord was used. usually it was heavy roots or a broken pipe. one of three things would usually happen: nothing, it would let loose, or twist/break.
        Re: 1500
        It was the factory cord plugged into the outlet, I will have to look at the clutch and see if it is slipping. Is it possible to just tighten up the clutch?
          Re: 1500
          Ditch the cable and get a "Rick Jetter". Blow anything to kingdom came and back again.
            Re: 1500
            If the clutch was slipping the jaws will have grooves cut into them. If that is the case call AJ Coleman and get a new set of jaws.
